Hello all,
I was just wondering if anyone knew if the European Vehicles category was included in the library for Vehicle Tracking 2015, and if so where we might find it/what it is called. I remember for 2014 there was an additional installer for this, which we only got after requesting it from support, however that of course is only compatible with 2014. I was rather hoping we wouldn't have to go through the same process this time and they would have included it in 2015 but now I'm not so sure...
Thanks.
Solved by nicolas.menu. Go to Solution.
Hi Jwilde,
You need to download and install from the subscription center (>Download>Product Enhancements) the package "Extended Vehicle Libraries for Autodesk® Vehicle Tracking 2015"
European vehicles are part of it and will appear under your vehicle library the next time you launch the product
Hope this helps
Cheers, Nicolas
Aha interesting thank you, I did wonder if like with 2014 it was an extra addon/download for it. I have had a look there now but unfortunately the only link under Product Enchancements is the Autodesk Revit Server Extension. This may be because I dont have the right level access currently though...?
Hi Jwilde,
If you do not see it it's because your contract manager within your company have restricted your access to subs.center.
I will take this one to one with you to solve the issue.
Talk to you soon...
Cheers,
Nicolas
This "Extended Vehicle Libraries for Autodesk® Vehicle Tracking 2015" is no where to be seen the Product enhancments section of our Subscription. Can you help us?
Thx
