Active Member
Brandon1865
Message 1 of 26 (678 Views)
Surveying Issue with dimensions and distances - AutoCAD Civil 3D
678 Views, 25 Replies
04-05-2013 12:22 PM
Hi there.  First off I'd like to say that I'm in the land surveying field, so I'm new to the layout of AutoCAD Civil 3D 2013.  Previously I have used AutoCAD Land Desktop.
I work primarily in 2d space and have set up my templates and settings to reflect those I used in Land Desktop.  Working on a few drawings today, I noticed when I went to dimension a building to the boundary line, the perpendicular command would become skewed and snap to a point far down the line.  When pulling the lengths with the distance command, the same thing would happen.  When I pulled the lengths and checked my math, I noticed the dimensions were utilizing delta-z dimensions rather than the delta-x or delta-y.
I know these two are related and I have searched the web for an answer, but I couldn't find anything related to surveying.  Thank you in advance for any help.
Brandon,
You will need to change the point style to reflect flattening them to elevation 0...
Ok point num 43 is off the parcel and it has a desc of CHK. I do not see any point marked as a brick column and I see only magenta lines and arcs.
Note that your prop lines all have varying Z values as do your points and blocks. Acad snaps perpindicular in 3 dimensions so if your start and end points do not have the same Z value the perpindiclar will not be correct for plan measurements.
The best way to get a perpindicular to your prop lines is to FLATTEN the prop lines to elv zero and set osnapz to 1.
jmayo
Message 2 of 26 (672 Views)
Re: Surveying Issue with dimensions and distances - AutoCAD Civil 3D
04-05-2013 12:29 PM in reply to: Brandon1865
You are snapping to points with different z values.
When measuring, dimensioning you may want to set the OSNAPZ system variable to 1.
If you are snapping to points you may want to use point styles (or edit the one you use) that display the points at z=0
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Active Member
Brandon1865
Message 3 of 26 (662 Views)
04-05-2013 01:06 PM in reply to: jmayo
Thanks for the quick reply John!
My OSNAPZ settings were at 0.  When I changed it to 1 it made the skew much worse.  As far as adjusting the display to be z=0, I deal with northing and easting location.  Could it be when I rotate the boundary its skewing the dimensions because I've messed up its alignment with GPS or some other thing?  I'm currently working my way through a "how-to" book but I have not seen anything about altering a project-wide rotation base.
Thanks again.
TRogers
Message 4 of 26 (657 Views)
04-05-2013 01:13 PM in reply to: Brandon1865
Sounds like your UCS is off.  Reset it by UCS>World, then PLAN>World.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
jmayo
Message 5 of 26 (655 Views)
04-05-2013 01:16 PM in reply to: Brandon1865
Ok first, in my last post I should have started with, "I think.." :smileywink:
Without seeing exactly what you are snapping two and what comands you are using this is tough. Posting a file would help.
If you draw a polyline across the dim lin does it skew?
Are you in a plan view? World coords?
Are there multiple objects under the line you are snapping perpindicular to?
I wouldn't think this has anything to do with GPS. I am still thinking this is the measure or dim is working with an elevation change somewhere. If you temporarily go to a Right View, does everything appear to overlap as a line at elev 0?
John Mayo, PE
IDSP 2014
jmayo
Message 6 of 26 (652 Views)
04-05-2013 01:20 PM in reply to: TRogers
The dist and dimension object commands should work fine with a rotated UCS.
John Mayo, PE
IDSP 2014
jmayo
Message 7 of 26 (651 Views)
04-05-2013 01:22 PM in reply to: jmayo
.. But the x,y, and z will be switched.
Yes the UCS will set that back but the values are good. I would think there is something else if the dimensions are skewing.
John Mayo, PE
IDSP 2014
Distinguished Contributor
SurveyorLee
Message 8 of 26 (611 Views)
04-05-2013 04:13 PM in reply to: Brandon1865
My bet is on the points being inserted at elevation.  I'm a surveyor too, and it drove me crazy, until if found how to insert the points at 0.  Another issue that may be encountered is line styles may look wrong.  A dashed line with a large z difference will not look correct when plotted, especialyy is there is a large difference in the z value.
Surveyor Lee
MtnMax700
Message 9 of 26 (606 Views)
04-05-2013 04:41 PM in reply to: Brandon1865
As a surveyor, the FLATTEN command has become my best friend in CIVIL3D.
David
SurveyorLee
Message 10 of 26 (581 Views)
04-05-2013 07:35 PM in reply to: Brandon1865
yes, i use it often, but when you have unlocked points in the dwg, you have to crash out to keep it from changing all of them.  Is there a way to cancel without crashing the dwg?
Lee
