Civil 3D Forum
Surveyed points v alignment report
7 REPLIES 7
Message 1 of 8
matkain
588 Views, 7 Replies
I have surveyed 100+ points along an alignment. I wish to create a report showing the perpendicular offset, chainage and z value for each point in relation to the alignment, and produce it in a csv or similar spreadsheet format.
How do I do this?
Thanks in advance.
Mat
7 REPLIES 7
Message 2 of 8
Joe-Bouza
in reply to: matkain
Toolbox tab>> alignment node should have sta off
Joe Bouza
Message 3 of 8
matkain
in reply to: Joe-Bouza
Sorry but I don't know what you mean.
New user to civil 3D here. Whats alignment node? whats sta off?
I can see the toolbox tab with the expanded alignment menu. I can't see anywhere that tells me to turn a 'STA' off or on? How does this create a report?
Message 4 of 8
Jeff_M
Sta = Station = Chainage
Off = Offset
This report should give you what you want:
Message 5 of 8
Joe-Bouza
OOps!
I meant the point node
in the toolbox tab there are nodes / colloection / folders - you know - like an exploreer tree. expand the point folder and there should be station offset report. highlight>> right click>>> execute, then adjust the dialgog for the points and alignment in question.
Tip: I like to export the points of interest make a clean file import the points and alignment then execute the report; its less cluttered, but not essential
Joe Bouza
Message 6 of 8
matkain
Thanks Joseph
Thanks for the tip. I notice that it includes all points in the drawing.Thats hard when there's 1000 points and you want 300. I'll export the point group I'll need and the alignment I suppose each time I do a report.
Pity you can't pick the points by group or description. (can you?)
Thanks once again and I'll keep stumbling through.
Mat
Message 7 of 8
MikeEvansUK
You should be able to select a point group in the reports, "alignment point station offset" report. I've not got c3d in front right now.
If you can't just export and import the data you need to a new dwg.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 8 of 8
matkain
in reply to: MikeEvansUK
Hi Mike
From what I can see you don't have any options for selecting your points. It's all or nothing, or the tedioius task of selecting each point individually with the tick box. I'm a bit lost as to why they give these options for point groups etc. in the drawing but then leave no options to access them.
I'll just go the double handling method of bringing them in to my main drawing, then to another drawing.
Rail Community
