Civil 3D Forum
Survey Link Problem Can not convert to fbk file
3 REPLIES 3
stevejames5886
482 Views, 3 Replies
I am trying to convert my TDS .raw file to a softdesk .fbk file and it does not work in Survey Link. It comes up with an error file in use.  Not sure what is going on with this.  How do I make htis conversion.  I have viewed the .raw file in Survey Link and it looks fine.
3 REPLIES 3
IanMcClain
in reply to: stevejames5886
If it says error file in use I would suspect you have the file open in another application, notepad or some other software. If that is the case be sure to close the other application when converting.
Ian McClain
stevejames5886
in reply to: IanMcClain
No that is not the problem.  I got around it by moving the file to the c:\ Civil3D Projects.  Did nothing different to convert but it worked from there.  I was accessing the file from a netwrok drive.  Not sure why it would not work like that?  Any thought why?
IanMcClain
Just speculation, but It may be some issue with your network's setup or lag due to traffic. I've had files do wierd things like that before. Sometimes I can't re-open a file I just closed with write privleges for 30-60 seconds because the network hasn't caught up and thinks someone else has the file open.
Ian McClain
Rail Community
