C3D 2012 SP 4
Win 7 Pro
Can I have combination raw descriptions on one shot? Example: bc1 e sw1 st
where I am ending the back of curb shot and beginning a sidewalk at the same point.
If I start linework with a curve, 3 shots, Example: ea1 pc, ea1, ea1 pt
Do I need a an extra shot (tangent) preceeding ea1 pc to get the curve to draw correctly?, or can I use
ea1 pc, ea1, ea1 pt to draw the curve?
Or do I have to envoke the st (begin) like this, ea1 pc st, ea1, ea1 pt
How does C3D handle reverse curves? Is ea1pc, ea1, ea1pc, ea1, ea1 pt the correct sequence fro drawing a reverse curve?
In a situation where a symbol is needed in a combination shot, the code for the symbol is first, then the linework, correct? Example: sanmh ss1 st
where a sanmh symbol and a line draw for ss1 (sanitary sewer line) are the same point.
Yes, you may combined figure prefixes.
No, you don't need a tangent line point to start a curve if you use the BC/EC (PC/PT) method. You may also define the tangents and a single point on the curve with the OC code. (see reference below)
If you start a curve and pick sufficient geometry along the curve to define the reverse curve it will come in just fine.
Symbols codes should be first in a description since the description key only matches on the part of the description before the first space.
Yes, you can code a point and linework in the same description.
Examples:http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-BCAEAD35-C361-40B7-ABF5-284FF36BA03-347.htm
