If one decides to use the H and V offset Figure Commands from the Linework Code Set....say for a gutter GUT B to create the top face of Curb [Gut B H.1 V.5] and to create the back of curb just [GUT B H.1 V.5 H.5] dont need the V.5 because i already used it for the top face of curb....anyways......it comes into drawing under the Figures category as GUT with a plus sign next to it and if you expand it Civil 3D named the top face fo curb GUT.1 and back of curb GUT.2
Am very happy with how they were all drawn as well
But when i go to make a surface, then right click the Figures category and select Create Breaklines...
The offset breaklines are not in that first box as an option.....I still have to go select them manually in order for them to be added as a breakline
Am i missing a small setting or is this what we have to deal with?
Thanx in advance!!!
Do you have the Desc Key field checked for use as breakline ?
Rick
Rick Jackson
Survey CAD Technician VI
yes i did
see attached word
it doesnt seem to want to automatically add the offset figures as an option for a breakline in the Create Breaklines box
for example
GUT.1 and GUT.2 were my offset breaklines for top face of curb and back of curb
but i only had a preset figure for GUT which i had set as a breakline if anything in the data collector started with GUT
GUT.1 starts with GUT ...... what gives?
thanx
I've had the same problem. Been wondering if the are going to fix this problem anytime soon. It's very annoying to have to select all figures created from offsets.
