hello,
i have some issues with survey database use and i need some guidlines please.
here is my problems:
i created a database that i would like to add some control points from time to time BUT if the new point have the same name with a point already stored in , i get the message " ignore the point" or " ignore all" .
why i do not have the " add counter " for example or the other options i have when importing points?
this is very inconvenient because i must cancel the whole operation OR only some points then find these points , remame , reimport....
what am i missing?
how you guys use the database?
thanks
Solved by achillesgr. Go to Solution.
A,
So you figured out a solution? Please share and tell us what you did, so that others might benefit.
Dave
Dave Stoll
Las Vegas, Nevada
Achilles,
I haven't done much with the Survey Database, but you can add an offset to any imported points, thusly:
You might have to peek at the point file with a text editor, ahead of importing, so that you'll know how much to offset.
Dave
Dave Stoll
Las Vegas, Nevada
Achilles,
I like the intermediate drawing idea. You could name it "Pointdump.dwg".
Dave
Dave Stoll
Las Vegas, Nevada
