I am looking for some help. My survey database was working fine over the last few months and then all of a sudden it tells me that ever survey database is not readable. No matter if I am trying to create one or open an existing one.
Error Message:
The survey database is not readable. You might not have access permisssions to the file or directory.
Source: AeccAdoNetWrapper
Message: Unable to find the requested .Net Framework Data Provider. It may not be installed.
Again it was working and now it is not. Any thoughts from anyone would be helpful.
See if this helps...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21935983&linkID=9240697
Also, make sure you are at least a power user.
