Civil 3D Forum
SURVEY DATABASE-NORTHING-EASTING VALUES
4 REPLIES 4
CADEngr2014
537 Views, 4 Replies
I am using Civil 3D 2015.
I have added some borings to a survey database and confirmed that the northing/easting values are as I would expect.  However, when I insert these into my drawing by highlighting the points in the prospector/survey tab, right clicking and select Insert Into Drawing, they have a different northing/easting value as shown in Prospector points.  What the heck is causing this variation?
4 REPLIES 4
Letif
in reply to: CADEngr2014
Check the datum of your drawing by going into settings from the prospector. The datum of your drawing and the datum of your soil boring location should much
CADEngr2014
in reply to: Letif
Letif,
Thanks for that response.  I have NAD83 North Carolina, Us Survey Foot in drawing file and [SPC] NAD83(2011)/NAVD88 US Survey Feet in the point csv file originally started with to create survey database.  I am not exactly sure what SPC means or (2011) reference to NAD83.  What is in the above datum that would cause this descrepancy?
CADEngr2014
Also, if there was a discrepancy in datums (the cad file being different from the point csv file) wouldn't that cause the points to import incorrectly into the survey database originally?
IanMcClain
Hi CADEngr2014,
Check your survey database datum settings. This can be found by right clicking on the database and choosing "Edit survey database settings..." or from the survey pull-down menu.
Both the drawing and the survey database have independent datum settings. If they are different a conversion will take place when data is transfered from one to another, unless one of them is "no datum, no projection". This is what I often find is the problem when in your situation.
Ian McClain
Rail Community
