Civil 3D Forum
survey database coordinates off
3 REPLIES 3
jmatte2004
345 Views, 3 Replies
i have a point file specifically a PNEZD file. when i import points into the survey database the coordinate in the database is correct but the coordinate on the drawing tends to be 5 feet off one way and 1 foot off the other. When I import point through the points pull-down menu the coordinates are correctly shown. When I import point into survey database from drawing the coordinate is incorrect in the database but correct on screen. Any help about what might be going on here.
jason
3 REPLIES 3
tcorey
in reply to: jmatte2004
Check to be sure you have set either International Feet or US Survey foot in both the Drawing Settings and the Survey Database Settings. Having one of these set to International and the other to US will cause a problem like what you describe.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
jmatte2004
in reply to: tcorey
thanks tcorey that was the problem. our templete drawing was set to international foot something i never thought about.
thanks again
jason
stacy.dunn
You should also be aware that any transformation settings you have set to the drawing will be applied during an import from the database.
Stacy Dunn
Rail Community
