Valued Contributor
jmatte2004
Message 1 of 4 (228 Views)
survey database coordinates off
228 Views, 3 Replies
02-23-2012 10:01 AM
i have a point file specifically a PNEZD file. when i import points into the survey database the coordinate in the database is correct but the coordinate on the drawing tends to be 5 feet off one way and 1 foot off the other. When I import point through the points pull-down menu the coordinates are correctly shown. When I import point into survey database from drawing the coordinate is incorrect in the database but correct on screen. Any help about what might be going on here.
jason
Check to be sure you have set either International Feet or US Survey foot in both the Drawing Settings and the Survey Database Settings. Having one of these set to International and the other to US will cause a problem like what you describe.
You should also be aware that any transformation settings you have set to the drawing will be applied during an import from the database.
tcorey
Message 2 of 4 (224 Views)
Re: survey database coordinates off
02-23-2012 10:54 AM in reply to: jmatte2004
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Valued Contributor
jmatte2004
Message 3 of 4 (214 Views)
02-23-2012 11:33 AM in reply to: tcorey
thanks tcorey that was the problem. our templete drawing was set to international foot something i never thought about.
thanks again
jason
Valued Mentor
stacy.dunn
Message 4 of 4 (207 Views)
02-23-2012 11:56 AM in reply to: jmatte2004
Stacy Dunn
