Hello everybody.....was wondering if someone could enlighten me, cause I think I am making an elementary mistake and can't figure out how to do this. When I import Points (w/o Survey Database) that contain Point UDP's they come in just fine, (see attached). However, when I import those same Points thru the Survey Database it does not populate the addition UDP info on the Point Label (see attached). Why? I have created the Styles, Point File Format and I have even added data to Survey DB Extended Properties.
Thank in Advance for any replies!
K
Solved by mathewkol. Go to Solution.
Jeff...thanks for the reply. I have tried this in 2012 and 2013 to no avail.
Yes I am at AU and will be talking with you later.
K
