Civil 3D Forum
Survey Database and Point UDP Labels
3 REPLIES 3
C3D_User
574 Views, 3 Replies
Hello everybody.....was wondering if someone could enlighten me, cause I think I am making an elementary mistake and can't figure out how to do this.  When I import Points (w/o Survey Database) that contain Point UDP's they come in just fine, (see attached).  However, when I import those same Points thru the Survey Database it does not populate the addition UDP info on the Point Label (see attached).  Why?  I have created the Styles, Point File Format and I have even added data to Survey DB Extended Properties.
Thank in Advance for any replies!
K
3 REPLIES 3
Jeff_M
in reply to: C3D_User
Hey K, no AU this year?
What version is this in? I thought that this was a wish list item added in one of the recent releases.
C3D_User
in reply to: Jeff_M
Jeff...thanks for the reply.  I have tried this in 2012 and 2013 to no avail.
Yes I am at AU and will be talking with you later.
K
mathewkol
There are a few things you need to do. This help page tells you all you need to know.
http://docs.autodesk.com/CIV3D/2013/ENU/filesCUG/GUID-3E88B795-F2E0-40E8-9F51-E628C3294B93.htm
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
