We recently tried to convert a RAW data file to FBK and the program aborted after running several setups. I have viewed the raw data on the data collector, but there appears to be no error. What other methods of conversion could I use to convert the RAW data file to a TXT file? I was hoping that our local AutoCad/Topcon dealer would be able to have a work-around, but they seemed stumped too. We have never encountered a problem usitlizing the Survey data Collection Link with any of our traverses prior to this time.
Thanks in advanced for any help,
TLH
Solved by ToddRogers-WPM. Go to Solution.
Try Stringer Connect. It's free and easy to use. If you can't find it, post back here and I will get it to you.
Wow, thanks for the quick come-back. However, when I accessed the site and tried to download I recieved as message "... StringerConnect.exe is not a valid Win32 application." So I guess I'll have to check with our IT dept.
TLH
Right click on the file that is attached here, StringerConnect200811Install.png and select Save Target as...
Once downloaded, rename it from a .png to a .exe.
