lbraff2648
Message 1 of 13 (923 Views)
SURVEY CODE OFFSET
923 Views, 12 Replies
09-17-2012 06:17 AM
I am just beginning to use the Survey features in Civil3D 2012 to generate a base map.  When we use the offsets, we are having issues when we have a negative number: BC ST H-.5.  The line will not offset, it just comes in directly on top of the original line.  When we use a positive number, it offsets correctly: BC ST H1.4 V.1.  Is there a setting somewhere that needs to be changed for it to read the negative numbers?  Thanks.
In the Edit Linework Code Set, I changed the Field Code Escape from "-" to "+" and now the offsets are coming in correctly.  Thanks to everyone for the efforts.
Distinguished Mentor
rl_jackson
Message 2 of 13 (896 Views)
Re: SURVEY CODE OFFSET
09-17-2012 09:05 AM in reply to: lbraff2648
Even though this fuction exists I rearly use it. However, try adding a V0. My thoughts our that it is looking for a vertical offset as well and that is why nothing happens.
C3D12-13
Win7x64 6gb
lbraff2648
Message 3 of 13 (883 Views)
09-17-2012 10:26 AM in reply to: rl_jackson
I tried adding V0.0 and it didn't work either.  Thanks.
rl_jackson
Message 4 of 13 (877 Views)
09-17-2012 10:57 AM in reply to: lbraff2648
OK,
I ran a quick test and do not exhibit this issue. Below is how I had it set up
1000,760086.2853,2435408.5935,555.2727,BC1 BEG H-0.5
1001,760083.5208,2435435.5897,555.2210,BC2 BEG H-1 V1
Added: I am running SP2
C3D12-13
Win7x64 6gb
AllenJessup
Message 5 of 13 (873 Views)
09-17-2012 11:03 AM in reply to: rl_jackson
I see one difference between your example and the OP's. You used -0.5 and the OP used -.5.
So I'd suggest the OP try -0.5 instead of -.5.
Allen
rl_jackson
Message 6 of 13 (867 Views)
09-17-2012 11:10 AM in reply to: AllenJessup
That very well could be it, I alway but that 0 in front out of habit for less confusion, but maybe its required.
C3D12-13
Win7x64 6gb
lbraff2648
Message 7 of 13 (866 Views)
09-17-2012 11:12 AM in reply to: rl_jackson
This one offsets to the right correctly:
134,7014363.181176,11836190.984148,394.089449,BL ST H1.4 V.1
This one doesn't offset to the left, it's directly on top of the original line:
104,7014263.834784,11836296.056239,394.991292,BC ST H-.5
I have several others that are doing the same thing.  I don't know what is going on.  I thought maybe it's a setting somewhere that I need to change, but I have looked in Help but couldn't find anything.
I am now thinking that I could be the custom Point File Format that we created to bring in Field Notes with the survey point labels.  It was to read any number after the "-" as another column, instead of a negative number.  I now have to figure out how to change that.
Thanks again for the help.
lbraff2648
Message 8 of 13 (865 Views)
09-17-2012 11:13 AM in reply to: AllenJessup
Adding that additional "0" didn't work.  Thanks.
Valued Mentor
engrtech
Message 9 of 13 (851 Views)
09-17-2012 11:52 AM in reply to: lbraff2648
We regularly use codes such as: FC ST H-.5 V.5 H1.5 V.1275 for having the back of curb to the left of the figure and the gutter to the right.  This doesn't cause us any problems, so I'm not sure what is happening on your end.
IDSP 2015
Windows 8.1 Pro 64-bit
8GB RAM
rl_jackson
Message 10 of 13 (844 Views)
09-17-2012 12:53 PM in reply to: lbraff2648
I would recommend that you try the OTB PNEZD format and see if that works.
AND / OR you need to remove the dash from your format and replace it with another character line # $ ! or something.
C3D12-13
Win7x64 6gb
