Okay. I think I have this figured out somewhat. We have a mixture of data collectors that run both TDS Survey Pro and Trimble TSCe Survey Controller.
They both output a JOB format. They all download to the same directory. They look the same. Most of the people in the office ignore them and use the TXT file.
See the reply I got from Trimble below:
Matthew,
Survey Controller .JOB format is different than a TDS .JOB format.
There are some system limitations that you should note when using the Trimble Link software:
The software only operates with version 7.00 or later of the Trimble Survey Controller software.
Trimble Support
I reasoned that as some of the JOB files we have downloaded are easily read by Springer Connect while others are just gibberish and give inaccurate results.
To echo Jason Hickey's post on Civil3d.com - TDS doesn't seem to be the way to go. There will need to be an intermediate FBK generating program (old Trimble standalone link or Foresight DXM) to convert to FBK to get observations into the survey database.
Do I continue to ignore the JOB/RAW files and just import the reduced coordinates? or do I attempt to fix this.
Matthew Anderson
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
