Dan,
Excellent suggestions. These are both issues that have been identified - in
particular your first suggestion. I am sure you have seen this, but there
is an option to rebuild the surface dyanamically when a Terrain edit occurs.
This option is called "Rebuild - Automatic". This does rebuild the surface
when the breakline is deleted. However, your suggestion would improve the
overall performance.
Daniel Philbrick
ISD Civil Development
"danbonenfant" wrote in message
news:30275406.1075728488869.JavaMail.jive@jiveforum2.autodesk.com...
> We need to have a method for deleting multiple surface lines in a single
selection either by window, crossing or fence.
> Adding a brealine creates new points in the surface and re-triangulates to
these points. I would like to have breakine points deleted when the
breakine is deleted without having to rebuild.
