Good morning everybody...
I am a regular user of Civil 3D, but I am finally getting into the meet and juice of this incredible tool, and as a result I am working determining cut and fill volumes to be represented in cross sections for discussion with contractors. I have an issue and is this:
I have 3 surfaces, EG (Existing Ground), Final Datum (Final design grade surface) and a undercut for 4 inches that has to be excavated below my datum but it is incidental to the common excavation to the datum grade, when I am assigning my two surfaces for comparison, the cut is between the EG and Final Datum for paid item, and then for cut under incidental, the 2 surfaces compared are final datum to undercut (4 inches below datum), and in here it is showing full cut under the final datum within the boundaries of the final datum surface which is not right, please see attached graph for a better understanding of this...
My question is this, how can I tell Civil 3D that I need my cut to stop at the Stripped topsoil surface between the final datum and undercut surfaces? I hope this question makes sense... it is driving my crazy
Thanks to all
Oscar
Solved by tcorey. Go to Solution.
It appears you've had 12" of topsoil stripped and wish to calculate the earthwork volumes using the bottom limit of topsoil stripping as the top excavation limit?
If so, Create a New surface, Name it Topsoil Stripped > Paste your EG surface into it >use Raise/Lower Surface to lower Topsoil Stripped surface 1 foot.
Now use this surface as the comparison rather than the EG for your volume quantities.
By pasting the surface into the EG, if the EG changes, the stripped surface updates reflecting any new changes once rebuilt.
This should explain the process:
http://timsc3dblog.blogspot.com/2014_01_01_archive.html
You wouldn't need to add the "vertical" links on the assembly.
@Anonymous wrote:It appears you've had 12" of topsoil stripped and wish to calculate the earthwork volumes using the bottom limit of topsoil stripping as the top excavation limit?
Thank you Jay.... Appreciate your time helping me here. What you explained here is what I did at the beginning, developed the surfaces needed and then comparing, the problem was that I was using Base and comparison surfaces and as you know, there are a maximum of 2 surfaces to be compared when using this tool. It is very helpful when you know the limits of your disturbed areas, and you want to know either cut or fill volumes by the dashboard in the volumes and materials panel, but it becomes an issue when you have more than two surfaces and they interact with each other, like in the pdf provided.
You have cut below topsoil (EG) on the ditches outside the limits of pavement and towards your pavement structure you have fill within the same surfaces... hope you understand my point. Thanks for the help!!!
Oscar
Civil 3D 2014 - 64 Bit
@intel Core (TM) i7-4800MQ @ 2.70GHz
16.0 GB RAM
NVIDIA Quadro K1100M
