I am having this same error. I have an existing ground surface made from feature lines. And a proposed ground surface made from a corridor. When I create a volume surface to find the cut and fills I get the 'Surfaces do not overlap' error.
As far as I can tell the surfaces are overlapping, in both the section views and the object viewer. This has never happened before.
Simular to the issue in this thread
Edited by
Discussion_Admin
Solved by wfberry. Go to Solution.
In the original thread, the OP eventually found that the EG surface was basically empty. Have you confirmed yours has valid data?
Draw a rectangle around the entire site -- it'll be used as a reference point in the screenshots blow.
With the FG surface set to No Display, turn on the EG surface triangles and boundary. Take a screenshot to show what it looks like.
Now do the opposite -- set EG to No Display and turn on the FG surface triangles and boundary. Take another screenshot to show what it looks like.
Post the two screenshots.
Don Ireland
Engineering Design Technician
I have attached the two screen shots. My EG is fine, but perhaps my corridor surface isn't really a surface? I created a surface of the corridor when I made my corridor and it appears in the list of surfaces. I've created section views with it but when I hover my mouse over the surface in plan view it doesn't give me any data like it does for my EG.
I usually have problems with corridors and end up cheating and creating feature lines from the alignment/profile to get my final surface. So I've probably done something wrong...
Corinne
Can you post your dwg file so we can troubleshoot?
Don Ireland
Don,
I've attached the CAD file. I'm working on two sections of road so I have separate EG and corridor surfaces in the file. If you don't mind taking a look at it and letting me know what I've done wrong, that would be so very nice. My corridor experience is minimal.
Thank you!
Corinne
Corrine:
Go to Prospector, select either of your non-existing surfaces. Rt. click "Corridor-North", select Surface Properties, Statistics tab. Notice that this is blank, so no surface has been made.
You need to go to the corridor section in Prospector to make your surface. Rt click one of your corridors and go to the Surfaces tab.
Here is where you determine what surface you want to use. Notice you have several choices under the "specify code".
Normally you would select Top for finish grade contours, Datum for calculating earthwork. (you have to select the "+" for each) You can have both.
You may already know all of this so I want use any more space.
Bill
Infrastructure Suite 2014 Premium SP 1
Bill,
I did what you said and I now have a volume surface in my dashboard! However I don't believe the volume I am getting is correct. I am a bit lost when it comes to setting up the links and codes. Would I be asking too much for a screen shot of the corridor surfaces tab with the correct information I need to put in? Perhaps this will help with my confusion.
Thank you,
Corinne
DanielBurns3250 wrote:I did what you said and I now have a volume surface in my dashboard! However I don't believe the volume I am getting is correct.
What are you seeing that leads you not to trust the info?
Don Ireland
My volume quantities are showing very high cuts with not much fill. I'm expecting lots of cut but my fill volume should be much higher than a few hundred cubic meters. My quantity takeoff criteria probably isn't populated property so I need to deal with that. Thank you.
Well when you create a surface from corridor, there are a ton of options there, but the two that are easiest to stick with are "datum" and "top" Datum is generally the bottom of all the section links, so that's kind of the subgrade equivalent, and "top" will use the top of all the links, giving you a finished grade volume.
Note that using datum would require you to accurately reflect all material depths.
