Civil 3D Forum
Surfaces in Prospector
4 REPLIES 4
ignich
538 Views, 4 Replies
Why can I not delete all the surfaces from my prospector.  It works for some but not others.  There is nothing left in the drawing; no points, lines ect. and there are no alignments or profiles.  The drawing is blank, yet the surfaces remain.  I think that there is some connection to another component, but I don't know what it is.  Any help is greatly appreciated.
4 REPLIES 4
Sinc
in reply to: ignich
I seem to remember seeing that happen once...  I think I added some data to the Surface, so I could see it in modelspace.  Then I selected it in modelspace and erased it there.
Sinc
mathewkol
in reply to: ignich
Select "Surfaces" in the prospector. Select all of them in the item view (botton half of the prospector). Right click and choose "Select". They should all be selected regardless of whether you can see anything or not. Then just use the Erase command or the Delete key.
If selecting the all at once doesn't work you can do one at a time.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
ignich
in reply to: mathewkol
Thank you Matt.  The "Select" then "Delete" worked.
NoXrefs
Thank you.  This was driving me crazy.  I really don't like how surfaces are handled in C3D.
Rail Community
