Civil 3D Forum
Surfaces.dwt in AutoCAD Civil 3D 2014
2 REPLIES 2
sheriff12
708 Views, 2 Replies
In the Surfaces Tutorials: Exercise 1: "Creating a TIN Surface". The first instruction is to click "NEW", which I did. I selected "Surfaces.dwt per instructions and clicked open. I have executed these steps a number of times to be sure I am doing what the instructions say. But, every time the same thing happens. "Drawing2.dwg" opens instead of "Surfaces.dwt". I also make sure the file type is set to dwt.
2 REPLIES 2
Jeff_M
in reply to: sheriff12
WHen creating a new drawing from a dwt all you are doing is creating a new drawing BASED on the specified dwt. SO what you are seeing is exactly what is supposed to occur.
Jeff_M, also a frequent Swamper
sheriff12
in reply to: Jeff_M
I finally realized that what was happening was supposed to happen after I just continued the tutorial. Thanks!
Rail Community
