In the Surfaces Tutorials: Exercise 1: "Creating a TIN Surface". The first instruction is to click "NEW", which I did. I selected "Surfaces.dwt per instructions and clicked open. I have executed these steps a number of times to be sure I am doing what the instructions say. But, every time the same thing happens. "Drawing2.dwg" opens instead of "Surfaces.dwt". I also make sure the file type is set to dwt.
Solved by Jeff_M. Go to Solution.
