Civil 3D Forum
Surfaces creation. I need change coordinates.
4 REPLIES 4
215 Views, 4 Replies
I need help. I have a lot surfaces. Now i need change coordinates.
Someone can help me?
Thanks.
4 REPLIES 4
antoniovinci
Did you just try a "draw query" between the first CRS and the second one?
in reply to: antoniovinci
sorry, how to do it
thanks
if you move the points boundaries ext... to the new coordinates the surface will follow. Warning: if you also select the surface then the surface will be moved the same distance and angle off of your definitions.
thanks, but i need change de coordinates.
Rail Community
