Dana -
I knew I had seen that somewhere - so thank you for the blog entry. After figuring out how to prepare the chart, I got the results I needed.
At this point the behavior of the analysis tab seems odd to attempt to work at it this way. (Don't get me wrong - I makes some neat and colorful analysis)
The range "spreadsheet" isn't formated for easy editing. I can not add a row to it without using the ranges "area" above. This resets any edits below.
The results are similiar to coffee made in a blender - a little chunky.
I am trying to prepare a record drawing for a detention pond that was built. While I can print the volume calculation, I need to provide the stage-storage curve to prove out that the contractor completed the detention pond with adequate volume regarless of the fact they didn't exactly get the construction correct.
Maybe this is a wishlist item to provide a little more functionality to that dialog box. (probably a little to late for SP2?)
Matt Anderson
anderson at jaseng.com
LDT 07 / C3d 07
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
