Valued Contributor
Buzz123
Message 1 of 1 (41 Views)
Surface to LD2005
41 Views, 0 Replies
12-22-2004 02:53 PM
I've edited a LD2005 surface in C3D and I now want to return it to my LD2005 project. I used the Extract Civil3D data and it indicated that everything worked OK. the head view of Terrain Model Explorer indicates that I've got a new surface with 17679 Points and 1070KB, however there is no data in any of the TIN Data items. The directory has 3 files: .tin, .sdf and a .pnt.
I guess I'll try LandXml to import the surface, but why woudl the Extract Data not work.
Any ideas?
Michael
WinXP SP2 1.9GHz 768MB RAM
LD2005 SP1
Civil3D 2005
Michael
Civil3D 2012
HP Elitebook 8560w
Core i7-2820QM (2.3-3.4GHz)
nVidia Quadro 2000M 2GB
www.foxsurvey.co.nz
