Distinguished Contributor
11 Kudos
Post 1 of 7
Surface Table Names
356 Views, 6 Replies
07-06-2011 04:29 AM
Is there a way for a table linked to a surface (ie. a volume table) to display the surface name in the header? There seem to be no options to do so and copy/pasting <[surface name]> into the header text box just returns a number, oddly.
I will have upwards of 40 surfaces and I don't want to have to manually edit each one!
Seems like a bizarre and simple omission seeing as the tables are dynamically linked to the surface anyway.
Any ideas?
Cheers,
Kevin
173 Kudos
Post 2 of 7
Re: Surface Table Names
07-06-2011 09:02 AM in reply to: ksorsby
I ran into that issue once.  Unfortunately, I found no good way to do it.
For me, it wasn't too bad, because I only had a couple of Surfaces, so I created a Table Style for each one.  I wouldn't want to do that for 40 Surfaces, though...
Sinc
11 Kudos
Post 3 of 7
07-06-2011 10:03 AM in reply to: Sinc
I thought as much. I'm going to file this one under Half-Baked Functions That Autodesk Can't Be Bothered To Sort Out.
Cheers,
Kevin
173 Kudos
Post 4 of 7
07-06-2011 10:27 AM in reply to: ksorsby
Yeah, there's an awful lot of C3D that falls into the "half-baked" category....
It gets frustrating.  But on the flip side, it's possible to do an incredible amount of high-quality work in a very short time frame with this software, even in its current "half-baked" state.  So if it ever gets "fully baked", it should be pretty awesome...  :smileywink:
Sinc
12 Kudos
Post 5 of 7
12-19-2012 09:16 PM in reply to: Sinc
Plus one... Please ADD!!
Civil 3D 2014 (SP2)
Win 7 Pro x64 -DELL Precision Workstation T3500
Intel Xeon 3.3GHz (w3680) -24Gb Ram
NVIDIA Quadro 2000 (1GB)
ceethreedee.com
Valued Contributor
0 Kudos
Post 6 of 7
01-03-2013 03:58 AM in reply to: ceethreedee.com
can you insert a field into the table style? use object. then name... just guessing at this point
Windows 7 64
Intel Core i7 2.0 GHz 2.0 GHz
8 GB RAM
Nvidia GeForce GTX460M
Civil 3D 2012 SP2.1
11 Kudos
Post 7 of 7
01-04-2013 02:23 AM in reply to: d1of2
There's no option or dropdown that I can see to enter anything other than text into the header text component editor.
It's a royal PITA when you've got a lot of tables lying around.
Kevin
