Civil 3D Forum
Surface Table Names
6 REPLIES 6
ksorsby
620 Views, 6 Replies
Surface Table Names
Is there a way for a table linked to a surface (ie. a volume table) to display the surface name in the header? There seem to be no options to do so and copy/pasting <[surface name]> into the header text box just returns a number, oddly.
I will have upwards of 40 surfaces and I don't want to have to manually edit each one!
Seems like a bizarre and simple omission seeing as the tables are dynamically linked to the surface anyway.
Any ideas?
Cheers,
Kevin
6 REPLIES 6
Sinc
in reply to: ksorsby
I ran into that issue once.  Unfortunately, I found no good way to do it.
For me, it wasn't too bad, because I only had a couple of Surfaces, so I created a Table Style for each one.  I wouldn't want to do that for 40 Surfaces, though...
Sinc
ksorsby
in reply to: Sinc
I thought as much. I'm going to file this one under Half-Baked Functions That Autodesk Can't Be Bothered To Sort Out.
Cheers,
Kevin
Sinc
Yeah, there's an awful lot of C3D that falls into the "half-baked" category....
It gets frustrating.  But on the flip side, it's possible to do an incredible amount of high-quality work in a very short time frame with this software, even in its current "half-baked" state.  So if it ever gets "fully baked", it should be pretty awesome...  Smiley Wink
Sinc
ceethreedee.com
in reply to: Sinc
Plus one... Please ADD!!
Civil 3D 2021 (Update 1), ACAD (SP1.3) MAP (HF0.4)
Infraworks 2021.1,
Win 10 -DELL Precision Notebook 7730
ceethreedee.com
d1of2
in reply to: ceethreedee.com
can you insert a field into the table style? use object. then name... just guessing at this point
Windows 7 64
Intel Core i7 2.0 GHz 2.0 GHz
8 GB RAM
Nvidia GeForce GTX460M
Civil 3D 2012 SP2.1
ksorsby
in reply to: d1of2
There's no option or dropdown that I can see to enter anything other than text into the header text component editor.
It's a royal PITA when you've got a lot of tables lying around.
Kevin
Rail Community
