AutoCAD Civil 3D General Discussion
Distinguished Contributor
SeattleCADD
Message 1 of 6 (634 Views)
Surface Style with Elevation Ranges
634 Views, 5 Replies
03-21-2011 09:59 AM
Hi All,
I am looking a surface style that has elevation ranges when viewing in model and plan. In the default template I see a elevation banding (2D) style, but it is not my need.
If anyone has this surface style, could I have it too!
Thanks much!
D
*Expert Elite*
Joe-Bouza
Message 2 of 6 (623 Views)
Re: Surface Style with Elevation Ranges
03-21-2011 10:36 AM in reply to: SeattleCADD
when using the 2d band style, you tell your surface what the elevation ranges is to be on the analysis tab of the surface properies. Or perhaps I do not understand your question clearly.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
SeattleCADD
Message 3 of 6 (609 Views)
03-21-2011 01:04 PM in reply to: SeattleCADD
The elevation band 2D is just for viewing plan only. i want the surface style with elevation ranges so when I view it in 3D, it has colors by elevations.
Please see attached file.
Employee
peterfunkautodesk
Message 4 of 6 (587 Views)
03-21-2011 01:55 PM in reply to: SeattleCADD
The elevation banding in Civil 3D can be used in both Plan and Model view. You need to make sure that you change your surface style in model view to display the elevation bands and then shade the model produce a similar picture. You should turn off the "triangle" so that only the elevation faces are drawn.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
SeattleCADD
Message 5 of 6 (583 Views)
03-21-2011 02:13 PM in reply to: SeattleCADD
I already tried but it is not display elevation ranges when I view it in model. i did exactly what you said but no luck yet.
Can you tried on your end and give some more directions!
Thanks.
*Expert Elite*
Joe-Bouza
Message 6 of 6 (554 Views)
03-21-2011 07:47 PM in reply to: SeattleCADD
Did you turn the light bulb on in the style for 3D view?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Announcements
Need installation help?
