I'm trying to create a cut and fill map and was wondering if anyone was succefull at labeling a surface with spot grades that have different colors according to what range they belong to. For instance, If I have a cut and fill surface with 10ft cut (max) and 10ft fill(max), Then from elev 10 to 5 the spot grades would be light green, 5 to 0 the spot grades would be dark green, 0 to -5 light red, -5 to -10 dark red.
I think this can be done using expression, but I not sure what the formula has to be.
Any other other ideas on how accomplish this are welcome.
Check out Seth Hall's remedy for this...
http://beingcivil.typepad.com/my_weblog/2009/02/color-cutfill-surface-labels.html
neilyj (No connection with Autodesk other than using the products in the real world)
