I have and expression that subtracts a value from my spot elevations so I end up with a truncated result. The problem I am having is that labels I have added text to, the expression doesn't work and I'm left with an untruncated result. Anyone know how to modify the expression so it will ignore the text override and still be applied to the elevation?
Thanks for the reply. Actually I have figured it out. Quite simple really. I just needed to clear my overrides and then re-apply new overrides with the style update.
Thanks again.
Jim
