Civil 3D Forum
Surface slopes on grid?
1 REPLY 1
726 Views, 1 Reply
I was wondering if it's possible to add surface slopes on grid (similar to how there is a tool for adding spot elevations on grid). I can do them individually at a grid spacing but that's tedious, and considering you can add spot elevations on a grid, I'm not sure why this wouldn't be possible.
If there isn't a built-in tool for this, would it be possible to make a block of a bunch of one-point spot slopes and you simply choose which surface & the insertion point when you insert the block?
Thanks!
1 REPLY 1
peterfunkautodesk
Use the ARRAY command or COPY the 1 Point slope labels across the surface. If you use ARRAY, make sure that it isn't an an Associative one (they don't like the slope labels).
Cheers,
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Rail Community
