Using Civil 3d 2012, I have a slope label with mult lines, and set to plan read.
When I rotate the label, the goes to plan read, but the bottom line text is on the top, top on the bottom.
I hope it would be simular to mirror.
I look at the expression, but didn't see any way to get the label angles.
Any fix or suggestions.
make a child style or copy style with the information reversed. all other setting stay the same.
or if you are using a two-point label, reverse the direction of the points.
Did Dan or Jeff's suggestion help at all? If not could you please provide some additional information and perhaps a screen shot and we will be happy to help.
Change the Orientation Bias. This will allow you to have one label style that will rotate the way you need. You will have to play around with it a bit.
i'm using the two point, howeve I do not see a how to reverse the direction.
I been creating Child for the label, however I need four label for each label. and it's a pain ever time I have to rotate the label, I have to change the style to a differn child.
Note: with bocks, I can flip to the left, and then filp down. one block all four quarent.
@rfg018 wrote:i'm using the two point, howeve I do not see a how to reverse the direction.
If the first point is uphill and the second downhill, use the grips to reverse it so the first point is downhill and the second point is uphill.
