"plt" wrote in message news:41bcdc6d_3@newsprd01...
> 1) Where are the controls for the little arrows that show up on surface
> profiles?
Select the surface profile
Right-click for context menu, select "Edit Profile Style..."
Switch to the Display tab
Edit the "Arrow" display component as you please
You can also do the same thing by switching to the Settings tab in the
toolspace (SHOWTS if not visible), then navigate to Profile > Profile
Styles and then the style you want to edit.
In the online help, go to Autodesk Civil 3D Help > Autodesk Civil 3D User's
Guide > Profiles > Profile Styles
> 2) Where are the controls for the slope/grade labels that show up on
surface
> profiles. I have a surface profile with many grade labels jumbled
together,
> and would like to delete some grade labels but leave others. Is this
> possible?
This is controlled by the label style.
Right-click for context menu, select "Edit Labels..."
Edit the "Lines" label component by editing the parameters in that
component, or by editing the style associated with it. This controls the
slope labels on the profile. You can control the start/end stations and
interval for the slope labels, and set a "weeding" factor if you want to see
fewer labels.
Edit the "Grade Breaks" label component by editing the parameters in that
grade break labels.
Guide > Profiles > Profile Labels and Label Styles
Himanshu Gohel. Civil3D Team, Autodesk, Inc.
Autodesk Civil3D Product Information <>>
