Civil 3D Forum
Surface not cooperating
6 REPLIES 6
Chaznsc
304 Views, 6 Replies
I have a file I have been working with for a few months now, and all of a sudden, the existing surface has crapped out on me. The surface and linework is thill there, but it wont label elevations or even list them. If I explode thew surface the resulting polylines are intact with elevations.
6 REPLIES 6
Citadel2012
in reply to: Chaznsc
Is it a data shortcut? If so, try deleting the reference and re-inserting it. Have you audited the drawing?
______________________________________________________________
To Err is Human; To Really Foul Things Up Requires a Computer.
Chaznsc
in reply to: Citadel2012
Thank you for the reply. Its not a shortcut.Audited it, fixed whatever was wrong and its still acting up.
Its been fine up until today.
Citadel2012
You could try copying and pasting the exploded contours (with correct elevations) into a blank drawing, creating a surface from those contours, and data referencing it into the file with the issue.
Chaznsc
i went and recreated the surface. Same issue. Created a new surface from pretend contours, sasme thing. There is a bug in this file apparently.
Lisa_Pohlmeyer
Need a little more info please:
What version are you using?  SPs up to date?
You say you recreated the surface, did you do this in the same drawing?  Have you tried a new drawing?
What is the data used for your surface?  Points, breaklines, etc?
If points, are they native in the drawing or from a point file?
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Jeff_M
If you could post the drawing someone may be able to figure this out for you.
Jeff_M, also a frequent Swamper
Rail Community
