Civil 3D Forum
SURFACE modify by deleting point
16 REPLIES 16
Message 2 of 17
mcloughlin
4835 Views, 16 Replies
We have a surface with some bad points.  We have these points displayed, along with the contours.
We go Modify>Surface>Edit Surface>Delete Point.
Program says: "You must have surface points displayed for this operation.  Edit the surface style and try again."
Yet here are the points, displayed right in front of us! (see appended image)
What are we missing?
16 REPLIES 16
Message 1 of 17
mcloughlin
in reply to: mcloughlin
Message 3 of 17
IanMcClain
Those appear to be cogo points, which are different than surface points.
If you have created a surface from cogo points as from a point group, you may edit the point group to exclude the points you don't want. The surface will update accordingly.
Surface points are usually added manually and only exist as a part of the surface object, therefore they must be displayed by the style to be edited or deleted.
Ian McClain
Message 4 of 17
Pointdump
McL,
Take out the bad points. Put in good points.Smiley Happy
Where to delete surface points depends on how the surface was built.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 5 of 17
sboon
You are displaying COGO points, not surface TIN points.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 6 of 17
jmayo-EE
Assign a surface style that displays the surface points in Plan. The points are turned on in the display tab of the surface style properties dialog
John Mayo
Message 7 of 17
wfberry
If they are just regular cogo points, just "move", "delete" or whatever in a normal fashion.  (Provided they are not in a survey database.)
Bill
Message 8 of 17
wfberry
Why am I seeing two posts that are the same?
Bill
Message 9 of 17
Pointdump
in reply to: wfberry
Bill,
I think McL's Enter Key stuck.Smiley Wink
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 17
Discussion_Admin
I merged these two posts
Discussion_Admin
Message 11 of 17
sboon
in reply to: Discussion_Admin
That was quick.  Must be real slow in the Admin world today Smiley Happy
Steve
Steve
Message 12 of 17
Joy.Gu
right click on the surface you are editing (under Toolspace > Prospector), select 'Edit Surface Style'. In the pop-up window, go to 'Display' tab, turn 'Points' component on. Points symbol will now appear on your surface, and you should be able to deleted points from surface.
Note: point symbols may be be huge, you can change sizes under Points tab > Points Size
Message 13 of 17
huamani1277
Hola buen día, me parece que no esta visible los puntos de la superficie, para la edición
 de la superficie debe estar visible los puntos y el TIN.
JHM
Message 14 of 17
neilyj666
in reply to: Joy.Gu
I'd hope the OP had got this sorted out by now after 8 years....
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 15 of 17
Dude, your reply is very vague
Message 16 of 17
mgutierrezZDFQ3
you stuck😂
Message 17 of 17
mgutierrezZDFQ3
you stuck 😂
Rail Community
