Civil 3D Forum
Surface memory size
4 REPLIES 4
diegoal
409 Views, 4 Replies
Surface memory size
Hello guys,
How can I know the memory size of a TIN or DEM surface? I have a very dense points data to create a surface and I would like to test what option would be the best: simplify the surface removing points or make it raster...
Thanks!
Diego Álvares
Civil Engineer @ Trento Engenharia Ltda.
www.trentoengenharia.com.br
Autocad Civil 3D 2010 to 2017 - Infrastructure Design Suite
Windows 7 64 i7 4770 @3.40GHz 8GB Ram GeForce GTX 760
Please use the Accept as Solution or Kudo buttons when appropriate
4 REPLIES 4
ToddRogers-WPM
in reply to: diegoal
One option would be to create the surface in a new, clean drawing.  Then data shortcut in the surface to your project files.  This will keep your drawing file sizes to a minimum and your memory usage down.
Todd Rogers
troma
in reply to: ToddRogers-WPM
You could also copy the drawing with nothing but the surface in it and test the different methods of reducing the file size.
Mark Green
Working on Civil 3D in Canada
seattlesurvey
Also, remember that the drawing size will be impacted by the surface style in use when last saved.  For example, your saved drawing will be smaller if the surface style is a "No Display" style versus a style which displays contours and TIN lines.
HTH.
diegoal
in reply to: seattlesurvey
Thanks guys, what you are suggesting can indicate the proportional impact of each surface... and maybe it should be good enough.
But I was expecting to calculate the TIN memory size by the number of triangles and its size in bytes vs the number of pixels and its size in bytes. So I guess I should write a VB code to be able to get the number of triangles (TIN) and valid pixels (DEM).
Isn't this the memory size of these ARX objects?
Diego Álvares
Rail Community
