Civil 3D Forum
Surface Labels
9 REPLIES 9
Message 1 of 10
tonykhoury
494 Views, 9 Replies
Surface Labels
Hi all,
Does anyone how to export surface spot elevation labels ? I downloaded an app called import/export surface labels, but it does not export the Z, only X and Y which is uselss.
Thank you in advance,
Tony
9 REPLIES 9
Message 2 of 10
rkmcswain
in reply to: tonykhoury
Export them to what? What are you trying to do?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 10
Hidden_Brain
set up the label style so that the label text is located at the insertion point of the label. then explode all labels to mtext entities, and run data extraction.
Message 4 of 10
neilyj666
Why are you needing to do this as there may be a more efficient way of doing it.?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 10
TerryDotson
It looks like that app is designed to export label properties for the sole purpose of importing into another drawing.
We have added that functionality to the development build of Gizmo3D, it creates a CSV file with X,Y,Z values.
We're having problems with our primary email server this weekend, if you have problems contacting us, use sales [at] dotsoft [dot] biz.
Message 6 of 10
tonykhoury
in reply to: rkmcswain
RKMcswain,
I am trying to either export the surface label to excel x,y,z or convert them into points on the surface. I have been trying to do this for a year.
Message 7 of 10
tonykhoury
in reply to: neilyj666
Neilyj,
Tony
Message 8 of 10
tonykhoury
in reply to: TerryDotson
TerryDotson,
Do you have a trial version ?
Tony
Message 9 of 10
neilyj666
I believe a time limited version is available for trial
2015-05-19 07_47_41-Civil3D Civil Survey & GIS Add-on Tools - DotSoft Gizmo3D.jpg
Message 10 of 10
Joe-Bouza
in reply to: Hidden_Brain
@tonykhoury
You can add a block with an acad point at the insertion point to the lable style, triple explode, convert the acad points to cogo points that can be exported to xyz or simply use
Joe Bouza
Rail Community
