Distinguished Contributor
SteveAdams8888
Message 1 of 11 (3,122 Views)
Surface Labeling: Display Contour Label Line...default to False?
3122 Views, 10 Replies
06-22-2011 05:05 AM
When I label contours by "Contour Multiple", I get a line going thru my contours. I can remove this thru the Properties pallette.
Is there a setting somewhere to make it default to not draw a line?
Steve
C3d 2010 (no SP)
Win7
Toolspace>Setting, right click on Surface>Edit feature Settings>Contour Labeling Defaults>Display Contour Label line = False
Hi Steve-
You can change existing labels by selecting the labels and going to the CONTOUR LABEL LINE PROPERTIES and setting the DISPLAY CONTOUR LABEL LINE to FALSE:
You can also set this in the command setting by editing the AddContourLabeling DISLAY CONTOUR LABEL LINE to FALSE. This way you will never see the line when labeling:command.png
Active Contributor
marcross
Message 2 of 11 (3,115 Views)
Re: Surface Labeling: Display Contour Label Line...default to False?
06-22-2011 06:03 AM in reply to: SteveAdams8888
Product Support
SethHall
Message 3 of 11 (3,114 Views)
06-22-2011 06:06 AM in reply to: SteveAdams8888
Hi Steve-
Seth Hall
Product Support
GCSO - CSS - FTS
Being Civil
Being Civil Twitter
Being Civil Facebook
SteveAdams8888
Message 4 of 11 (3,105 Views)
06-22-2011 06:48 AM in reply to: SethHall
Thanks marcross and Seth. I appreciate that!
Steve
C3d 2010 (no SP)
Win7
CrazyIvan
Message 5 of 11 (2,162 Views)
06-17-2013 01:18 PM in reply to: SteveAdams8888
I do not see this option in Civil3D 2010.  Is it located elsewhere in 2010?
Jay_B
Message 6 of 11 (2,156 Views)
06-17-2013 01:42 PM in reply to: CrazyIvan
Should be here.
Settings Tab of Toolspace>Rt. click on "Surface">Edit feature Settings>Contour Labeling Defaults>Display Contour Label Line = False
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
CrazyIvan
Message 7 of 11 (2,153 Views)
06-17-2013 01:47 PM in reply to: Jay_B
Not on mine. See attachment.
Jeff_M
Message 8 of 11 (2,147 Views)
06-17-2013 01:51 PM in reply to: CrazyIvan
CrazyIvan, rt click on Edit Feature Settings, NOT on Edit Label Style Defaults.
CrazyIvan
Message 9 of 11 (2,142 Views)
06-17-2013 01:57 PM in reply to: Jeff_M
heh.  my imaginary dislexia strikes again. LOL  Thanks.
Active Contributor
twillis004
Message 10 of 11 (1,462 Views)
01-29-2014 06:45 AM in reply to: CrazyIvan
Weird, I followed this string but when I set the Contour Label Line False , its still showing up?  What is up with that?
