Civil 3D Forum
surface is transforming twice
2 REPLIES 2
balloonsrise
204 Views, 2 Replies
When I move and rotate a surface along with its survey points and breakline definitions, and then rebuild, my surface gets thrown off double the amount I’ve transformed it. I go to surface properties, and then under Definition, an operation type shows how much I moved it. if I uncheck it, the surface pops back over the points and lines where it should be (where I moved it to). My question is, why is this transformation making itself happen again?
Civil 3D 2013
Windows 7 64-bit
Inteel 2.40 GHz 8 GB RAM
Dell T7600
2 REPLIES 2
mathewkol
in reply to: balloonsrise
Don't move the surface AND its defining geometry. Do one or the other.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
balloonsrise
in reply to: mathewkol
That was it. Thanks Matt.
Civil 3D 2013
Windows 7 64-bit
Dell T7600
Rail Community
