When I move and rotate a surface along with its survey points and breakline definitions, and then rebuild, my surface gets thrown off double the amount I’ve transformed it. I go to surface properties, and then under Definition, an operation type shows how much I moved it. if I uncheck it, the surface pops back over the points and lines where it should be (where I moved it to). My question is, why is this transformation making itself happen again?
Solved by mathewkol. Go to Solution.
That was it. Thanks Matt.
