i built a surface (titled 'difference') by attaching a point file in the definition pulldown, and now the surface is multipling and my dwg file size is now huge!
you can see in the attached file the dozens of replications of the surface 'difference' with numbers in paranthesis following (not sure what those are referring too), which change/update periodically based on what i am doing on dwg, but i havnt figured out what in particular is causing the surface to mulitply or why.
also, what is the little yellow triangle next the the surface icon - as this seems to identify a status that is preventing me from deleting
thanks!
Solved by mathewkol. Go to Solution.
neilyj (No connection with Autodesk other than using the products in the real world)
