Civil 3D Forum
surface intersection
8 REPLIES 8
Message 1 of 9
7900 Views, 8 Replies
is there a way to extract a 3D poly line where two surfaces intersect each other.
i have ground surface and i have dam surface. they would like to show the filler material in the cross section graph.. so i copied then raised the surface the required depth.
so now the surface and side slope of the dam intersect. and i would like to trim the filler material surface to be in line with the dam.
8 REPLIES 8
Message 2 of 9
> each other.
Could you subtract one surface from the other and contour the zero
elevation line on the difference surface?
Terry
Never start any job without the right tools!
AutoCAD Add-on Tools at http://www.dotsoft.com
Message 3 of 9
mathewkol
Make a volume surface comparing the 2 surfaces. Then display only the 0 contour. Use the surface utility "extract objects from surface". And pick the 0 contour. Then drape that over you main surface to create a 3d object.
Matt
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 4 of 9
Joyfer
This link is an explination on how to use the Minimum Distance Between Surfaces command!
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Finding-the-intersection-between-two-surfaces/td-p/31...
Message 5 of 9
neilyj666
in reply to: Joyfer
I hope the OP hasn't been waiting 5 years for this reply...Smiley Wink
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 6 of 9
jayDB5
in reply to: mathewkol
How would you display only the 0 contour(s)?
Message 7 of 9
Jeff_M
in reply to: jayDB5
@jayDB5, Welcome to the forums!
In the Surface properties, go to the Analysis tab, choose the User Defined Contours, add 1 at 0 elevation. Then make sure your surface style is set to show user defined contours.
Jeff_M, also a frequent Swamper
Message 8 of 9
neilyj666
in reply to: jayDB5
As Jeff has replied....but I think this would have been better as a new thread...!!!
Message 9 of 9
Alfred.NESWADBA
in reply to: jayDB5
...or set just contours to be displayed in the styles and set the interval of contours to 100000 or a value that is larger than the topmost elevation.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Rail Community
