I am start work in civil 3d 2009, I have a project started in LDD2009 and am trying to migrate to civil 3d 2009. I have imported the points, tin, and contours but cannot figure how to create an actual EG surface. Can some on etell me how to create and actual EG surface using tthe tin and points.
When you say you imported the "TIN". Are you referring to the actual tin or just the 3D lines that represent the tin?
One way would be to recreate the Surface using the points and breaklines. You can use the 3D lines but that might give unexpected results. Another way would be to export the Surface from Land to an XML file and import that to Civil 3D.
Allen Jessup
Allen Jessup
CAD Manager - Designer
I have found and imported the actual tin file I assume this means I have an actual surface to work with?
@AllenJessup wrote:...
You can use the 3D lines but that might give unexpected results....
What unexpected results? If you have the TIN lines in the drawing, they are probably 3D faces, not 3D lines, right? One thing to be sure of it to check the box "Maintain Edges from Faces" when you add them to the surface.
The only unexpected results I've experienced in that case is that the surface will triangulate across concave areas around the edge, so you need to add a boundary to restrain it.
Mark Green
Working on Civil 3D in Canada
Maybe my experience is from before "Maintain Edges from Faces" or before I learned about it. I remember points being created within the triangulations. I used 3D lines because they were more universally accepted when sharing surfaces with non-LDT users.
I now always recreate a surface from points and breaklines since Civil 3D creates better surfaces than Land did. I only resort to other means if those aren't available.
Allen Jessup
Allen Jessup
Glad you're on your way. Post again if you have further questions.
Allen Jessup
Allen Jessup
