I have an issue where I have created a top-of-road surface, but there seems to be a random object in the middle of it that is creating a skinny mountain in the middle of my road.
I have swear I have looked at everything. I've rebuilt the surface several times, played with corridor sections, profiles, alignments, points, manually deleting and adding tin lines, etc, etc.... but can't seem to figure it out. I am sure now I have just played with it for so long that I am probably just be missing something obvious that is right in front of my eyes.
Could someone take a look at the attached files and help me figure this one out?
Thanks in advance for your time.
Rob
(Note: Normally I would care, but we are doing alot of volume comparison suraces based on this surface, and I need to be sure our numbers are fairly accurate...)
Here is the first attachment - autodesk's file size limit is prohibiting me to attach all the files needed.... Sorry but I can only make Civil 3D drawings so small...
so.... i cant get the CAD file up here... If someone is interested I could email it... I'm only allowed to uplaod 1.5MB files here and my CAD file is 14.612 MB...
Hey Jeff, I have just figured out that it has to do with the assembly section inthe cul de sac that is in line with the street 1 profile.... Just trying to fix it now...
Wow, good catch. I was just coming back to say that I was not finding the cause (although I did see in 3d view that it looked like an assembly was running back to the cul-de-sac). I did work around it by deleting that 1 point on the surface.
Turn on the display of Surface Points in the Surface Style. Select the surface, go to Edit Surface and choose to Delete Surface Point, select the single point that is on/near the centerline where the spike occurs.
However, this is not a real fix, as I have witnessed the spike to actually be in different locations. The problem is coming from the corridor frequency section that is exactly in line with the centerline. It appears that the target is missing the radius point of the bulb and is randomly finding a point on the centerline. To avoid this issue I removed the Horizontal Geometry points from the frequency setting for the cul-de-sac region. This prevents a section from being created at the midpoint of the ep alignment which is the offending section.
