I have a 212km² point cloud with 399794764 point in the database (PCDB). When I create a suface of the point cloud, the surface only has 777478 points which is only 0.194% of the original points.
My question is how does Civil 3D determine how many points to use from the PCDB to create the surface from?
I am using 2011 64bit on a Dell T7500.
Solved by nicolas.menu. Go to Solution.
The limit via Point Density is 1 500 000 points (POINTCLOUDDENSITY at 100%).
777 478 point for the surface indicate a POINTCLOUDDENSITY of about 50% at surface creation time.
Thanks for the reply.
I have got point density set to 100 on the point cloud tab.
