Civil 3D Forum
Surface from corridor
3 REPLIES 3
DAVE8171
498 Views, 3 Replies
When creating surface from corridor, the new surface comes in at the origin (0,0,0) even though alignments, other surfaces, corridor are in the correct state plane location. There are no lines going to origin and no surface acual appears. all layers turned on and a visible contour style applied Cross sectyions plotted correctly. Ideas?? See attached
Pictures:
Zoom to Extents (all survey data, Surfaces, profiles, cross sections etc.)
Zoom to Surface (zoom to surface under Surfaces.
3 REPLIES 3
troma
in reply to: DAVE8171
Did you add any data to the surface yet?
Mark Green
Working on Civil 3D in Canada
troma
Here:
http://docs.autodesk.com/CIV3D/2013/ENU/index.html
Mark Green
DAVE8171
in reply to: troma
I didn't go far enough in the Surfaces under Corridor Properties.. I "created Corridor Surface" but I didn't add the Top & Daylight, thus the error.
Thanks for your help!
Rail Community
