DAVE8171
Message 1 of 4 (372 Views)
Surface from corridor
372 Views, 3 Replies
01-20-2014 08:48 AM
When creating surface from corridor, the new surface comes in at the origin (0,0,0) even though alignments, other surfaces, corridor are in the correct state plane location. There are no lines going to origin and no surface acual appears. all layers turned on and a visible contour style applied Cross sectyions plotted correctly. Ideas?? See attached
Pictures:
Zoom to Extents (all survey data, Surfaces, profiles, cross sections etc.)
Zoom to Surface (zoom to surface under Surfaces.
Did you add any data to the surface yet?
troma
Message 2 of 4 (367 Views)
Re: Surface from corridor
01-20-2014 08:57 AM in reply to: DAVE8171
Credit where credit is due! Give kudos or accept as solution whenever you can.
troma
Message 3 of 4 (367 Views)
01-20-2014 08:59 AM in reply to: DAVE8171
Here:
http://docs.autodesk.com/CIV3D/2013/ENU/index.html
DAVE8171
Message 4 of 4 (342 Views)
01-20-2014 11:18 AM in reply to: troma
I didn't go far enough in the Surfaces under Corridor Properties.. I "created Corridor Surface" but I didn't add the Top & Daylight, thus the error.
Thanks for your help!
