Hi everybody,
As i mention I have a problem with a surface generated from a corridor - I cannot set the boundaries
I add as boundary the corridor and it's not working
I also add the daylight as boundary and it's still not working
Does anybody know how to solve it or it's a bug
Select "Use corridor extents as boundary". What version are you using? You might have to rebuild the surface, or rebuild the corridor.
thank for your reply
I already try that and it's not working
iI'm using civil 3d 2013 with no updates
Your Name
Post the drawing as an attachment so that someone else can take a look at it.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
I find that adding a boundary interactively often works when the corridor shrinkwrap doesn't. You can effectively chop out troublesome areas.
Kevin
