Solved by mathewkol. Go to Solution.
Your second suggestion led me to the solution. I went back to almost the original drawing which for some reason now showed all dimensions multiplied by a factor of 12. I scaled everything by 1/12. I then created the contours which now were correct in all 3 dimensions. Thank you very much.
