Civil 3D Forum
Surface Elevations - JPEG Image file
3 REPLIES 3
theremm
421 Views, 3 Replies
Hi, I am trying to edit the elevation of a jpeg image I have brought into my C3D 2010 file as an xref - I essentially want to 'drape' the image over the existing ground surface I have created to use for presentation purposes i.e. to show how our road layout is predominantly located along the ridgelines of the site.
Typically for other file types I would perform the following steps (using the classic toolbar): Grading > Edit Feature Line Elevations > Elevations from Surface > Select the existing ground surface > select object.
I don't seem to have the ability to select my jpeg xref using this approach... how else can I perform this task?
Cheers
3 REPLIES 3
neilyj666
in reply to: theremm
i dont go as far back as 2010 but you wont be able to extract anything ftom a jpeg. you should be able to drape the image over the surface though.
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
theremm
in reply to: neilyj666
Not looking to extract any info from jpeg, simply drape the image over the surface for graphical presentation. How would you do this in later versions then if not familiar with 2010? Cheers
neilyj666
Select the EGL surface and then In the Surface Tools ribbon select Drape Image and follow the dialogs
Rail Community
